2007 280 EC Depth Sounder
The Main ExchangeThe Main Exchange Member Posts: 280 ✭✭✭
Has anyone had problems with the factory depth sounder giving inaccurate readings?
  • The Main ExchangeThe Main Exchange Member Posts: 280 ✭✭✭
    We are currently out of the water having the engine replaced so I was thinking get this done at the same time. Does the Lowrance fit into the existing dash hole?
    The Lowrance should fit the same hole in the dash. Are you going to replace the existing in hull transponder with a new one or are you going to put a transom mounted unit on?
