BRAVO 3 OIL TRANSOM FITTING
jhofmann
Member Posts: 430 ✭✭✭
I have a 2000 242 with a Bravo 3 outdrive that I broke the nipple off the fitting going through the transom for the gear lube reservoir while changing the gimbal bearing. I know it has to be disconnected from inside and pushed out, but I can't even see it, much less get at it in the engine compartment. Does anyone know how this is dine, or if the engine has to come out?
