Anchor Upgrade for 342
I have a 2005 342 Fiesta Vee and I am looking to replace the anchor as it is definitely underweight. Has anyone upgraded the anchor and if so what size were you able to go up to without having to reconfigure the boat.
    JP- stock anchor now? I've never had a problem with the anchor being undersized on my 342, even in 6-8' seas. You do have chain on your rode, yes?
    What type of bottom do you anchor in? You might have the wrong type, not underweight.
  • TonyWalkerTonyWalker Posts: 744 ✭✭✭
    I swapped our plow anchor for a Manson Supreme.  Fits the same set up, no changes required.  Big difference.  When it grabs the bottom, it owns it.  It is made in New Zealand.
    Tony
    Salt Shaker 342
  • craigswardmtbcraigswardmtb Posts: 1,015 ✭✭✭
    I would second Tony's recommendation.  I had my Delta give on me a couple times and I moved to a Rocna (almost identical to a Manson) and went up one size.  I have been in some heavy winds in crumby bottom surfaces and have not moved an inch.  I sleep much sounder now while under anchor.
    I have never had a problem with my anchor..........
