1995 265 air conditioner ideas
youstolemybeer
Member Posts: 246 ✭✭✭
HELP. the boat is too hot inside to sleep. even with 2 fans blowing on you its like an oven in the cuddy. What do other cuddy owners use as an air-conditioner. Im thinking a swamp cooler but am wondering if that would be very effective
Thanks
Steve.
I know some people use those portable A/C units available at most department stores. These are 110 volt units that can be run off shore power, or a small generator like Honda's 2000I. You will need to make an adapter to vent the unit through a hatch, or porthole. The moisture collects in a container inside the unit that will need to be emptied. There are small marine A/C units that can be mounted in the boat but require a through hull fitting to pump water through for cooling. My 242 has one located behind the stairs to the cabin that came from the factory. But again you will need shore power or a generator.
