Kohler 5E
Weber
Member Posts: 249 ✭✭✭
Off an one I have always had problems with my 5E, just like most people.
She stopped working on me again, so I dug into it again. Always the same issues, won't start or will while the button is held, along with surging.
Started with the normal stuff, plugs, filter, carb cleaning, ect...
Still would not start, but would with carb cleaner or starting fluid for a few seconds. Removed the anti die selling soleniod and made sure the plunger was free and it was. Cleaned it up just because and cycled it a few times. I noticed that when I connected it to the battery it will retract in, only if I applied pressure to it, then it would click right in. When removed, it would come back out, but not retract again without pressure. I couldn't find a plug to plug the hole for the soleniod to bypass it while testing, so I depressed it and wrapped some Teflon tape around the threads and pin. It held it in the retracted position, reinstalled it into the carb and cranked it over.
After a few attempts the bowl filled with gas and she started. Surged for a few, and a small choke adjustment had it running better than I have ever seen it run. I ran it for a few hours with no issues, cycled it a few more times off and on and started right up.
So, looking online I can find the soleniod for $65-$100. Anyone seen them cheaper? Anyone just eliminate it altogether?
Sin or Swim - Rinker 312
http://www.partsfortechs.com/asapcart/generator-parts-kohler-c-14_83.html
