The readings for the engine hours FV 270 year 2000
Jasm1n8Jasm1n8 Member Posts: 1
Is there.a gauge for the engine hours of FV 270 ? It is year 2000 boat. Thanks!
  • qwikwhipqwikwhip Member Posts: 63 ✭✭
    I have noticed a lot of rinkers don't have hour meters. My 2002 250FV doesn't either. However, if it has an ecu you can get the hours with a scanner.
    2005 Captiva 232 Liberty Edition, MX6.2/B3, Corsa
  • aero3113aero3113 Member Posts: 9,760 ✭✭✭✭✭
    My 2001 242 doesn't have one either.
    At best the stock hour meter is based on the lousy Faria gauge tach/hr meter. When my tach failed I was only guessing at run time. I found a solution in a basic 2003 version of a Merc Smartcraft gauge detailed in this link:  ((LINK))   Look for the images and solution details in my update around Feb 10th. The gauge works directly from the on-board engine computer and has a host of data including accurate engine hours/GPH/RPM/trim pos/temp/wtr pump pres/ etc.. Super easy upgrade once you get the parts.
    I found it NIB on ebay for about $150 and the cable was $50. Call Merc with your engine number to get the right cable part number for your application. Look for the merc gauge gurus name in the other post/link.
    Hope that helps, Mike
