276 Audio System issues
HunterHunter Member Posts: 2
(1st post)
As a brand new 276 owner I'm having some issues with the factory fitted audio system.
Only swim platform (rear) speakers working well others (cockpit and forward) difficult to program and not doing well.
Is there simple fix or other known issues regarding the six speaker system.
New owner United Arab Emirates
Best Answer
  • HunterHunter Member Posts: 2
    I tried that with no real success also the balance. Thanks for the response.
    Not sure if I was missing a mixer or multiplexor type arrangement.
  • JoeStangJoeStang Member Posts: 1,137 ✭✭✭✭
    The actual model number of the radio would help a lot.
    I'm guessing there's some sort of issue with the fade or other setting in the headunit. On my Sony you can adjust the fade and also the mid, low, and high frequency gain, which if its way out of wack could cause poor sound quality.
    Try going back to factory defaults and go from there.
    2013 276 Cuddy ~ 350 MAG / B3
  • Strother85Strother85 Member Posts: 38 ✭✭
    I noticed with my 276, sony system with arch speakers too, that I can barely hear some of the speakers until you turn the volume up quite a bit and then you can hear the other ones too.  It may have something to do with the way they have it wired to the amp and amp settings.  I'm not sure where the amps even are and there are supposed to be two in my boat lol.  I usually crank the stereo anyway so it doesnt bother me, but that was my initial observation with the system.
