RPM issues
dbond
Member Posts: 4 ✭
Hello, I have a 1996 rinker captiva 232, 454 7.4 l.. Bravo 3 ourtdrive. I'm running 28 pitch props. wot, im at 4000 rpm's, at 49 mph. any ideas to better mph, and up my rpm's.. Thanks
you can do things like select a rake that provides bow lift... a cup that compliments that... a progressive enough blade that bites you in out of the hole but shifts down the face of the blade providing more forward movement per revolution.... props are a witchcraft..
the BIII are gonna make the selection an issue... they are too expensive to buy-to-try... maybe you can locate a prop shop with the blue props? or maybe even one that allows you to pay a few bucks up front to test spin them...
http://www.mercuryracing.com/propellers/bravothreexr.php
Getting the correct prop will make the engine work the way it is supposed to. Don't worry so much about top end. Your engine is much more important. When you get the the correct RPM's at WOT. All the rest should fall into place.
