342 Nav Lights
 trich11
                    Member Posts: 108 ✭✭✭
trich11
                    Need new Nav lights for 2002/342. Does anyone have a part number for an LED replacement?
       trich11
trich11
Here is what I used for my LED nav lights.
http://www.amazon.com/Attwood-2-Mile-Mount-Navigation-Stainless/dp/B001O0DL56/ref=sr_1_4?s=boating-water-sports&ie=UTF8&qid=1404049884&sr=1-4
Here is the transom light. It fits the current Perko hole, no drilling...
http://www.amazon.com/Round-Stern-Transom-Light-Stainless/dp/B00D1CXF5Q/ref=sr_1_1?s=boating-water-sports&ie=UTF8&qid=1404050083&sr=1-1&keywords=Attwood+6556
Here is the all around light. If you have a radar, then it is different.
http://www.amazon.com/Attwood-LED-Anchor-Masthead-Light/dp/B003EWQNOS/ref=sr_1_1?s=sporting-goods&ie=UTF8&qid=1404050246&sr=1-1&keywords=Attwood+7812
Trich, you might find the problem I had when replacing mine: the hole drilled in the deck is close to the radius where the deck goes up for the bow running lights, most all the replacements I found would not cover the hole and clear the radius...I'm not sure these lights are available anymore, but page 15 of the attached catalog is what I finally found that works. I had to make a spacer to go with it to fasten to the deck and then the light to the spacer, I have drawings somewhere if you are interested.
BTW: the bow lights are heavily caulked from below and makes getting the light and wiring out a real pita. I had to work at it from the anchor locker access plate. That was joyful not.
  not.
Good luck!
Trich, on mine the wiring was all caulk covered too, I had to break it free from the underside.
There should be plenty of wire once it is free from the caulk. I had about 8 inches of wire to work with when I replaced mine.
