Does anyone know of a way to check a single speaker circuit other than with a known good speaker?
Have right front speaker with no sound. All connections are good and cone is not frozen. Is there a way other than having (removing one of the good ones) to check that circuit? On a Clarion system 4 ohm if it matters.
Yes! You can use a battery to make the speaker pop. This will also check the correct polarity of the speaker wires.
If you don't get a response from the speaker, it may be disconnected at the rear terminals, or blown.
I use an 18V cordless drill battery for this task, and have made a set of leads for checking speakers that are far away, or not in direct sight. A simple D cell battery will work in a pinch also.
I hope this helps.
MW
Thank you both. The battery is a great idea and a 9V works fine. Easy to carry. I confirmed with a good speaker as well, but also found you can check with and AC meter and it will show if the channel is putting out a signal. In my case, it is not.
