Engine shuts down when i tap gauges
Chrisvr6
Member Posts: 166 ✭✭
The previous owner installed new gauges in my 236 captiva with 454 mag. I tapped on the water temp gauge (diagnosing different issue) while running the motor on muffs and it shut down. It won't restart until i tap the right spot on the dash. Which gauge would shut down the motor like that? I did have a mysterious shut down problem last season while underway. Could this be it?
I'd be pulling the dash panels off and looking closely at wiring harnesses... the only thing, in my mind, it could be is an exposed wire on your key switch, and another exposed wire allowing a ground to happen.
i bet it would be fun trying to operate at speed with that issue.
i just don't get how a gauge would make the motor shut down. Crazy.
i doubt it is... I'm thinking an exposed ground is tapping an exposed lead on your ignition switch, interrupting it, and powz, engine dies.
Thanks. Will check. That vhf radio is making the depth finder do crazy stuff when its running too. First thing will be to disconnect vhf radio.
It was the craziest thing. Tapped the water temp gauge with just two fingers. Then it was intermittent and hitting different places on the dash.
So, did some digging behind the gauges. Purple wire on the oil gauge was loose and almost off the post. Seems ok now.
That's a nice and easy fix!
is there a feature that kills motor if oil psi is zero??
My mechanic said "yup, that'll do it". He said the purple wire is daisy chained throughout and that's the ignition circuit.
Your mechanic is correct
I thought the purple wire was the ignition monitor, as in the RPM gauge... But anyway, if something interrupts the ignition continuity, it ain't gonna run no matter what that is... You're just lucky it was at the terminal rather than in the pulls... That would be a monstor to track down.
but the purple wire goes through each gauge and the ignition.
and to think i tapped the water temp gauge with two fingers, one time, diagnosing my low water temp.
it is.
That is the way it was on my old 242fv
My guess is that your issue is at the tach. The tach simply reads the "pulses" from the distributor ( or brain box that controls spark) and if you ground the hot wire from the tach, you ground out your spark circuit. Emergency kill switches ground the distributor hot circuit so you have no spark. Many alarm systems use a relay that grounds the spark circuit if the alarm is actuated to prevent someone from hot wiring and starting the engine.
