stability in Lake Erie waves
jollyrodgers
Member Posts: 12 ✭
Considering selling our 260rd and buying a 276cc for several reasons but mostly for more stable feeling in Lake Erie chop. Any comments would be appreciated.
Beam means everything for stability.
if you are planning to move up. At least get to 30 feet as you'll pick up beam for stability.
Thank you. The 276 does have a wider beam and sits lower on the water. The 260 is more sensitive to the wind bc of the tall cabin. Just wondered what 276 owners thought.
The 276 is going to move around almost as much as your 260. Your only gonna gain about 7 inches of beam. For a noticeable difference I would suggest 10 beam or bigger providing you aren't worried about trailering.
I havent been in anything more than 3 footers on lake st clair, so I cant really say how it'd do in the more spaced out waves of Erie. I will say it isnt a heavy boat, so it will pound a bit unless you keep the bow very level and plow through the waves.
I would guess the center of gravity on a 276 is much lower than a 260, so at anchor it will likely rock quite a bit less. And a beam sea would maybe be more comfortable.
Either way the 260 and 276 are not massive, so neither are going to be very comfortable in any serious chop or waves unless you plow along.
I've been on the Jet Express (100 foot Catamran that does 40mph) on Lake Erie and it was getting its a$$ kicked. Nothing but sky-water-sky-water the entire ride. I cant imagine in a recreational boat......
I've done 4 to 5 in a 242FV and 6 footers in my 290FV all on Lake Erie weight beam and trim all make a big difference
We sea trailed ours on Lake Erie out of pot Clinton in 4 footers in the rain on purpose. Told the dealer if the admiral didn't feel good about the ride deal was off and we would have to look for a bigger boat. Maybe you could try and set something like that up, really it's up to you and the crew on what is to much movement / sway. Good luck
