insta-trim wiring 1994 265 FV
hey, does anyone know if rinker wired the trim tabs to the hot side of the igniton switch or did they go to the battery switch. Mine quit working and since I have been working on both the dashboard and the batteries Im not sure which spot to start looking at.
Thanks
Steve
On my 2000 242, I do not need the key on to activate the insta-trim tabs, so mine must go right to the battery. Not sure if this is the same as yours.
found it, it was a blown fuse behind the dash. 20 amps is a lot of juice, I thought you wanted the fuse as close to the battery as possible. seems odd that it would be behind the dash much less a fuse and not a breaker.
oh well its fixed
Steve
