Water going thru gas caps.
I have a 2005 Rinker 320 FV, and keep getting water in the tanks. We have eliminated the possibility of water coming in with a fill up. It seems to run off of the mooring cover directly over the caps. I replaced the gaskets on the caps, and stuck a small piece of paper towel under the caps, wet the boat, and the towel was wet with water. There is a definite problem with the caps, and they let in quite a fair amount of water. Where do I go from here?
Did you replace the o-ring on the caps? Not the gasket at the hull. If the o-ring is new and the right diameter I bet the vent in the cap is bad or worse case the fitting is cracked. I'd start with new caps.
My vent is built into the cap.
Here is the O-ring part number.
O-Ring Only: 054000099B
West Marine has them, sometimes in stock in their stores.
http://www.westmarine.com/buy/perko--o-ring-only-for-vented-fill-0540--14121917
Sorry for the multiple posts... The forum went down as I was posting.
Put new o-rings on and now all is good. I think the o-rings were $5 each
http://www.theoringstore.com/index.php?main_page=product_info&cPath=367_79_82&products_id=3484
for same reason
