fiesta vee 265 1994 Cabin door
Some lowlife tried breaking in the boat and kicked the door, its now busted up pretty good. any ideas where I can get a replacement?
Thanks
Steve
    From past posts the white "acrylic" doors seem to be really hard to get. I'm not sure who makes Rinkers doors but I bet it is Jet Technologies as they make a ton of Rinker parts and could probably make you a custom one if all else failed. Cindy Scott-Hagen at Rinker could probably put you in touch with someone at Jet Technologies... cscott@nauticglobalgroup.com If they had a template it would probably be less expensive. A guy at a marina near me had a similar problem but it wasn't a Rinker He said he took the old door as a tempalet to a fabrication shop and had a 1/8" thick aluminum door made and then had it powdercoated. He used the trucks (wheel system) from his original door and it was a beautiful job. It was expensive but his boat was fairly new and someone had forgotten to put the door stop in the door and it had slammed shut in a hard turn and cracked. He could not get an "acrylic" replacement.  Good luck MT
  • jfdeng5jfdeng5 Member Posts: 13 ✭
    Try Kendor Marine.  They are a place where boat parts go to die.  You never know what you will find there.  Here is their website.  Good Luck. http://kendormarine.com
    Thanks for the info JF5! We have been wondering on this forum if boat graveyards actually exist. It would be nice if someone is actually stockpiling used parts! MT
    You can try checker marine service lasalle michigan they part boats out all the time 300 plus of them
