Windlass question
glynnalan
Member Posts: 36 ✭
This weekend had my Rinker anchor out- from the beach- aft side facing shore. I had about 100feet of rode out- when pulling the anchor rode back in- getting about 30' to the end- it stops (motor still runs but rode not reeling in) if I drop it down 10' and pull up it begins to come in. I have to drop and pull up multiple times to get the anchor up in lock position. I adjust the port side 'nut' tight- is there something i'm missing or should adjust-- OR is it normal procedure to 'yo-yo' up and down at the end to secure??
Is it 'skipping" on the line to chain connection? That is pretty common.
The windlass is not made to haul your boat 'in' as you pull in the rode either. You can wear out the clutch on the windlass or overheat it. If you already have the clutch tight you may have worn it out too.
it just stops and motor hums 'freezes up'. dropping it and bringing it up again gets it done.
a friend suggested letting the rode all the way out to end and rewind?
