What color do I have?
ThellThell Member Posts: 37 ✭✭
Hi,
I would like to fix some bad vinyl on my 2005 320 FV but I don't know what color I have on the vinyl.
Greatlakeskippers have vinyl in stock in Rinker Light Gray Star Punch, Mystic White and Off-white.
  • mvnmvn Member, Moderator Posts: 754 mod
    You can contact Rinker Parts with your hull ID number.  They should be able to provide you with the colours.
    Mark
    2019 MTX20 Extreme
    Hi ,
    Your vinyl as probably change colour over the years due to sun and other pollutant so guessing the colour is pretty hard. Your best bet is to go under some cushion where the vinyl is tuck under get a sample from there and send it to the seller . And be aware that the new vinyl would be a shade off  on the seat where it will be replace.
    Your other option is to look for somebody that those professional repair on vinyl  good repair last a long time and and are not noticeable .
    Good luck
    Thell: I agree with Paul regarding getting a repair made if the hole/tear is not big. I have had this done and couldn't find the spot afterwards. MT
    RY
    What about all those volcanoes ......
    Volcanoes....Geez - what about all those Volvos? MT
  • MarkBMarkB Member Posts: 3,989 ✭✭✭✭✭
    Thell, is it a small repair. If so, as others indicated, you can call a professional to simply repair it. I did it on my white lounge seat, and I can't tell you where the repair was done, it is so good. It's lasted 2 seasons so far, so all good. Cost $100.
  • ThellThell Member Posts: 37 ✭✭
    Thank you for your suggestion, I will take it to a repair shop and try that before I do anything else.
    We don't have any Volcanos and the Volvos probably are more friendly to the environment than some other brands :-) even though I love to have a big american car but when a gallon of gas is appr. 7,90 US dollars you need to choose wisely....
    Diesel is almost exactly the same, there is like 3-4 cents difference in general but the Diesels don't need as much fuel as the gas so next time it will be a diesel powered boat :-)
  • rasburyrasbury Member Posts: 8,478 ✭✭✭✭✭
    sure, let's gunk up sweden's air with diesel smoke......
    from your pictures, your vinyl does not look that bad....you may be able to re color some of it as well. Looks like you might have the same as mine and I would call it an egg shell or off white with the gold/tan trim on it. Pretty hard to "match" with existing. I would nurse it along as long as I could and then replace all of it at once. Good luck!
