Water inside boat
I have a Captiva 2013 186 F/S I/O with a 4.3 mercruiser. When we cruise on the lake for 15 or20min water accumulates inside an I have to run the bildge pump often is that normal?
  • MarkBMarkB Member Posts: 3,991 ✭✭✭✭✭
    And it doesn't accumulate when you aren't moving? Is your impeller (cooling)  pump leaking?
  • mvnmvn Member, Moderator Posts: 758 mod
    Does your speedometer work?   If not,  check the tube and fitting behind the engine.  It is quite surprising how much water will come in when underway.
    Mark
    2019 MTX20 Extreme
    That is not normal at all.  ++ on the above suggestions.  I'd see if the water is coming in with the boat in the water and engine off.  If it stays dry, then run the engine at idle and look for leaks from the cooling system.  if still dry, then drive the boat and carefully have someone look for where the water is coming in from.
  • KYSEANKYSEAN Member Posts: 121 ✭✭
    Accumulates where? Isn't the bildge automatic?
    2012 Rinker BR216 5.0
  • SylvainSylvain Member Posts: 2
    water only accumulates when moving and the bilge is not automatic and the speedo is fine
    Is your water impeller leaking? Are you able to look in the engine compartment while running about to get a better sense of where the water is coming in from.
