Mid/forward bilge pump location
IanIan Member Posts: 2,999 ✭✭✭✭
FV310 2003 - any idea where the forward bilge pump is and how to access?
    Same here on my 312.  Just remove your cushions and you will probably have a plastic cover over the opening.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,833 mod
    It is under your mid cabin cushions. There are a total of 3 access panels under those cushions. On stbd size, rear access panel is bilge pump (you'll also see h/w heater drain hose there). Forward one is access to your shower sump, seacock for a/c pump, seacock for head pump. Port access panel has nothing.
  • IanIan Member Posts: 2,999 ✭✭✭✭
    Thank you all. I have been in the access where the heater is and the A/C condenser water but didn't notice the bilge as I thought it may have been further forward. I will check them out again.
