Foward Bilge Pump Fiesta Vee 250
Fiesta Vee 250-2004, Im new in this forum and  I will like to know where the forward bilge pump is and how to access?
  • awhiresawhires Member Posts: 53 ✭✭
    Should have a round porthole near or on the floor. Pry the lid off with a screwdriver if there is no handle. You probably have to feel around in there to un clip it from the base of the pump
    Most Likely a port under your aft mattress you can see your sea cocks and shower sump also
  • PamPam Member Posts: 73 ✭✭
    edited September 2014
    On my FV250 (2003) it is under the mattres directly under the stairs and in that porthole it is located to the starboard side of the shower sump. Under the pipes.
    (the sump is the white stuff on the right sid in the pic, the pipes are remowed)
  • jbasabejbasabe Member Posts: 4 ✭✭
    Thanks so much for the input.
    Seems that most Rinker models have the forward bilge, as well as the head through hull and AC through hull under the mattress in the aft cabin.  Similar question was asked for a variety of models in past, and from my member it's always come back to being under the mattress, including in my Rinker 260 EC.
