Wired on through hull valves
MarkB
Member Posts: 4,007 ✭✭✭✭✭
Hello Team!
Why are there wires going to my through hull fitting isolation valves? What are they for?
(frikken new image link system sux)
edit:
I just found this researching around:
Bonding Primer
For the most part, all metals touching sea water should be bonded, including seawater pumps, strainers, and plumbing. Moreover, all electrical equipment and large metal objects should be grounded to prevent electric shock and increase lightning safety.
Fuel tanks and fills should be linked with the main DC negative bus or a battery terminal. Bronze through-hull fittings are an exception. ABYC leans toward bonding, but also allows through-hulls to be isolated. As noted above, among the issues that can arise is wood damage—the tiny amounts of current passing through bonding wires can deteriorate nearby wood, including the wooden backing blocks that are often installed beneath the flanges of through-hull fittings.
Bonding of metal thru-hulls is interesting. In addition to the possible wood damage that BD pointed out, I've also read that a bonded metal thru-hull is more vulnerable to catastrophic damage in a lightning strike.
So, which risk is better for metal thru-hulls: If you bond it, a lightning strike could destroy the thru-hull and sink the boat. If you don't bond it, stray current could corrode the thru-hull over time, and if nobody notices, it could break and sink the boat.
Rinker bonded all of the thru-hulls on my boat. (My surveyor pointed out that the bonding wire on the AC intake is too small and not the right color.)
