454 to 350
Sunday I went out and lost oil pressure in my 1993 Rinker 260 , it has the 7.4 with a bravo one.
I'm going to pull it and was thinking on putting in a 350 for fuel millage, with the same horse power.
I have been thinking about the lack of torque at lower rmp with a smaller engine and would it be able to push the boat up on plane? is there any one how specializes in this type of swap , and know what all it would take?
x
the small block may produce similar numbers, but it won't be able to sustain those numbers as easily as the big block can... that equates to economy when there is a constant resistance such as boating, as opposed to on land.
Using that analogy, and we can only because the weight of the boat and the resistance of moving it through water are constants up to the point of plane, and certainly afterward...
The drill, set on the highest setting, and squeezing the trigger, can be easily stopped with one hand... the drill on the lowest setting, cannot be stopped by hand, but it doesn't turn fast enough to do anything to speak of... if there were two drills, both capable of the same speeds (horsepower) but one had a bigger motor behind it (big block) you could turn just as fast, But you wouldn't deplete the torque...
disadvantage? You gotta lug that heavy drill around... power, as in turning the same bolts, is going to be similar if not the same, as you'll find the bigger brushed motor doesn't warm up near as much as the smaller brushed motor does to do the same thing., and because it isn't working near so hard as the smaller one. ... And that is what it boils down to, in my opinion in boating -load on engine... the lessor the load you can manage, the better your economy... there comes a point where it's way too much power, mind you, but for two engine platforms in similar conditions/ranges (as far as power goes), the bigger one is almost always more economical. Strange but true... All about the load.
My 2014 260 has the 350 MAG, but with a Bravo 3. Cruises at ~3800RPM@~29mph. With full water, fuel, cooler(s) and 4 people, I have to turn 4000RPM. I did WOT it once for 20 seconds or so and the speedo-meter passed 45mph! No water and 1/3 tank of fuel, just me on the boat.
I have no idea what my fuel burn is, but it doesn't seem bad. The 4 times I have had it out since I bought it, I burned around 20 gallons (guesstimating based on fuel I've put in the boat/hours) each time I went out (per day basically). I usually spend a bit over an hour at cruising speed and maybe 45 minutes to an hour at around 1200 RPM (no wake mode).
Boat is still breaking in (only 10 hours) so ??? if those numbers will go down a bit.
Not sure if this helps, but that is my experience. My hull might be different/more efficient, and cleaner cause it's new. No bottom paint.
If I had the extra $12,000, and was ordering a boat, I would do a Volvo V8-380 just for fun. This was a boat show/end of year deal and was the largest motor option they had in stock. Also, I liked the all white with navy blue stripe vs. the colored hull sides, so buying the smaller engine'ed boats and swapping in a larger one didnt' make sense (and I didn't want to spend the $$$.
-=Mike G.
2014 Rinker 260EC
x
x
x
I found a place in Florida, RAPIDO marine 454 long block for 3500 and talked to him yester day for a good wile and he is not making wild power and fuel savings climes in the same sentence's, which tell me he may have the truth on his side.
if I was you I would follow Al to the letter.......
No basis for this other than what I have read on other forums but...
I believe others have had issues with RAPIDO marine. Do a google search and ask around before you make a purchase.
-=Mike G.
2014 Rinker 260EC
