Problem with jabsco quiet flush
The problem that I have is, the toilet on my 312 won't suck up any sea water in to the bowl. Its a jabsco quiet flush 37045 The valve  is open. If I pour water in to the bowl, it will shoot it into the holding tank no problem. Is this a case of toilet failure and replace it or is there something else going on. All the fittings are tight and lines are clear. Do I need to prime it?
Any help would be appreciated!
Thanks
    Check the strainer too, if it is plugged you'll get no water draw.
    Like Steve, given your information I suspect the pump. That pump should be on a breaker or fuse. As well, have you checked the connections at the pump, behind the toilet and at the panel for loose connections, bad ground and/or corrosion? MT
    Make sure the pump is running when you push the fill button. On my 342 I only 1 time take the fill hose off the pump fill it with water and it worked great. Again only 1 time in 7 years go figure. Give that a shot and see what happens... Good luck and keep us posted....
  • luckydogluckydog Member Posts: 316 ✭✭✭
    I thank you all for the great advice, Will be at the boat this weekend will keep you advised. Again thank you all very much
    edited October 2014
    Also if there is a slight crack in the line you could be drawing air. But likely the strainer is blocked.
    Post edited by MarkB on
    edited October 2014
    You guys where right it was the pump, There is power going to the pump but when I took it apart it was all rotted on the inside. Thanks for the help
