Oil change question
Since I have owned my boat, I have been changing the oil by sucking the oil out of the dip stick tube.  But I understand that the two lines that are clipped to the transom between the engines can also be used.  I have been avoiding touching them because they are rubber and didn't want to cause any leaks or anything.  But was wondering how others do the change, using those rubber lines, or using the dipstick tube?  I am betting that you can get a more complete oil change by using the rubber lines, as I only get about 4 quarts of oil out per change, and I believe my engines should hold at least 5.  Just wondering what others do.  Thanks.
    I use those lines and they work well. What engines do you have?  The 350 MAG MPI only holds 4.5 qts.
    I think we get a better oil change with the rubber hoses as far as removing all the oil and some sludge.
  • halifax212halifax212 Member Posts: 560 ✭✭✭
    I  use the drain hose. It takes a while but it is a clean procedure.Make sure the oil is warmed up or its really slow.
    I change my oil twice per season.  Once in the water by sucking the oil out of the dip stick tube ( this is mid season) then at haul out I use the line....it works great but slow, and same thing I can only get around 4 quarts or less out sucking the oil out of the dip stick.
    Since we are on the subject of oil changes, what does everyone do with the upside down oil filter to prevent oil from going everywhere? On my 232, the filter was on the bottom of the engine, which was still a mess. On my current boat with the 6.2L, it is on top. I have heard of driving a screwdriver thru the top of it to make a vent hole to help it drain. Any ideas or suggestions would be great!!!
    Yup: punch a hole thru the top and most all the oil will drain to the pan.
    Agreed with punching a hole on top less of a mess
    edited November 2014
    I use the oil lines you mentioned that attach to the oil pan drain plug.  They are braided lines and should be durable.  What engines do you have?  The 350 MAG MPI only hold 4.5 qts with a filter.
    I use those lines, they are braided and durable.  What engines do you have?  The 350 MAG MPI only holds 4.5 qts with a filter.
  • aero3113aero3113 Member Posts: 10,041 ✭✭✭✭✭
    I wonder if this would work well on our engines with the upside down filter?
    https://www.baxterperformanceusa.com/evac-u-filter.html
  • grouch0jrgrouch0jr Member Posts: 267 ✭✭✭
    Ilmore makes a remote oil filter mount with a built in drain:
    https://parts.ilmor.com/shop/base-engine-accessories/remote-oil-filter-mount/
    I've been curious if that would work with my engine, i just haven't finished my research yet. That purge system looks like a decent alternative for me if the Ilmore solution doesn't work. Maybe even better, less mess.
  • toolmaker312toolmaker312 Member Posts: 130 ✭✭
    I use the rubber lines also. My cousin gave me a pump that is attached to a 5 gallon bucket. The hose happens to fit over the engine hoses and sucks it out in 1 or 2 minutes into the bucket no mess. Thanks for the hole in the filter idea
  • Dream_InnDream_Inn Member, Moderator Posts: 7,965 mod
    @toolmaker312 I have that same pump I’ve been using for about 25 years now. Love it!  I’ve done the hole I. Filter, but honestly just having a bag under with old towels, I’ve never had any problems.
