Raw water cooling from hose
SeaShift
Posts: 27 ✭✭
I'm not getting any water through the drive to the water pump on the hose. Could it be obstructed. I took the hose off the pump coming from the transom assembly ran water backwards and it comes out of the drive easily. The engine will not pump water on the hose what so ever, which is obvious because I can't get water from the drive up to the pump. Any ideas.
2003 312 Fiesta. 5.0. Bravo 3
when you say you can't get water to the pump, with boat in water, does water come thru to the pump? You my just need to replace the impeller on the pump.
when I say I cant get water to the pump. With the intake hose off the pump. I hook up the garden hose and turn it on with plenty if pressure and can't get water to come out of the hose from the transom assembly
My mechanic told me about a customer who had a small snail inside the hose. After it crawled inside the hose, it grew large enough to obstruct the hose. Everybody was baffled until he removed the outdrive, took off the hose, and found the little critter.
