Scavenger hunt for missing items on Fiesta Vee 265
muskyfins
Member Posts: 8 ✭
Hello Everybody. Owned a lot of boats, but first Rinker was purchased over the weekend. Just can't find a few things. Where is
.the capacity placcard (or yacht certification)
.forward bilge/pump
Thanks in advance for any help.
.forward bilge/pump
Best Answer
howardrams
Member Posts: 223 ✭✭✭
On the newer 260 the forward bilge pump is in the compartment under the mid cabin mattress along with the seacocks and shower drain pump. Don't think they have a placard for yacht certified boats.
if its a 1995 the front pump is at the bottom of the cabin steps behind a hidden door. Open the door and you will find the valve for the toilet, and behind the valve slightly to the left is the pump and float switch.
When you find the placard let me know, been looking for mine since spring
Is this bilge connected to the main bilge?
A leaky fuel pump spilled gasoline into the main bilge which has been rinsed out, but the fumes in the cabin are pretty bad. I want to rinse the front bilge. But if they're not connected, I really need to find how the fumes got in there in the first place. I guess that was the point of original question on pump location.
There is a "mouse hole" under the aft cabin are where water from the main bilge can run into. Where does this lead? I was able to put 6" of water in the main bilge to rinse, so it can't go far. Does anybody know the structure or any way to get gasoline from the main bilge to the forward bilge?
Thanks to everyone for their help and support.
well said! I think the 1person per 3' length is a rough guess estimate that the CG would recommend minus gear weight.
