Recap my cooling issue
rasbury
Member Posts: 8,965 ✭✭✭✭✭
dang I am stumped! I have had a couple issues I have been working on, let me start from the beginning.
I have a 2005 270 5.7, bought around this time frame last year. Always had been a "slow" starting starter in play and the key would not always activate the ignition. So, I was taking the neighbors out the next day and was out there bumping the ignition to see if it would work or not, seemed OK. So, at the ramp, in the water started " slow " as usual, backed it off the trailer and up to the dock and got off, left it running to warm as I helped others with their stuff. Did notice the power steering hard but thought it was low on fluid. So, just about when we start to get onboard, high temp goes off and I turn it right off. Further inspection and the drive belt is broke and the raw water pump is frozen. So, home we go. I get the water pump off and very lucky that there are two big pieces jamming it up, new impeller back in, all looks good and back together. Go to test and starter is done. Did all the tests,come to the conclusion it is the starter, get rebuilt and back on last night. So, put the muffs on the bravo three out drive. I have a fresh water cooled system so I have two hoses- one to the out drive and one to a thru hull which the raw water pump pulls water from both hoses, into the strainer and then into one hose and then to the motor. Fires right up and sounding good! So, I'm watching the temp gauge, climbs slowly to 175...and then keeps going. I shut it down. I look in the strainer and there is no water in it. I removed the cover to it and turned the water back on to make sure I did not have back pressure and still, no water coming through from the out drive. I have not really looked at the out drive manual, not sure I have one, but should that water not be rushing through? Are there any other valves, check valves? I only ran the boat out of water on muffs a couple of times, once a short time to heat the oil to change it and anther I thought to flush it after salt water use. The water is trailer kept so I'm really puzzled. It was also lift kept previous. I'm going to go put it in the water and see if the thru hull will pull water into the system, my fake lake will not fit properly to do that out of water- have had no over heating issues at all since I purchased, maybe it has not been pulling through the foot the whole time.
My 342 with the same dual-pickup arrangement was notoriously finicky whenever I launched the boat after having it out of the water. If I just started the engines at idle, the pumps would rarely prime on their own. Sometimes, I could prime the pumps by revving the throttles for a few seconds. Most of the time, I would have to prime the pumps manually like this:
1) Disconnect the water hose on the output side of the strainer.
2) On the body of the water pump, loosen the air bleed valves (two blue plastic butterfly screws).
3) Manually fill the hose with water until water flows out through the bleed valves.
4) Close the bleed valves.
5) Reconnect the hose to the strainer, trying not to let any water leak out.
6) Fill the strainer with water.
7) Start the engine and hope the pump works.
The key is to make sure there's water actually inside the pump body when you start the engine. I don't know why that was necessary, but it usually worked.
It's something about the dual-pickup plumbing. There was another Rinker in my marina with the same issue.
It really does not make sense...i am really starting to think I
have a blockage in the out drive..
I guess the duplicity is ok, at least you know your going to get enough water from somewhere, like when your plained out, you might miss grabbing enough water from either by it self. I would be pretty sure they are not there on a whim. It states in the manual it needs the two to maintain req'd water flow.
Now then, tries what was suggested above with regard to priming, open the pump to let water flow but did not work for me. So, I stuck a hose down the removed main hose and does that pump suck some water! At just idle, it took all the hose from my house supply without a drop in the bilge. So at least I know , so far, I did not cook the impeller. If I have problems at speed then that's the first place I will check. It ran up to just below the 175 and held there so assumed the thermo is working properly as well....I do see why the muffs that I have can't get enough pressure, the actual outlet for the water is much smaller than the supply line. So hopefully now, with the system all primed up if I put it in the water it will draw properly. I don't think I would trust my muffs to supply enough water, even my fake lake has about a 3/8 actual supply size for the water...maybe with two hoses. May get to test yet this afternoon!
no go, would not pull water...guess the pump has something else going on, a leak somewhere. I did not pull the hoses off the back of the pump. Crud. I've read the other posts of problems with new impellers, I think this should have been pretty straight forward repair. But, on the plus side, I am learning the boat. The starter repair was good and the guy does alternators and marine gennys.
Back to the drawing board on the pump.
I'm a little confused about the discussions of the grooving at the top and bottom of each end of the pump. I do have some grooves and I do have some corrosion. The surface that the tips of the fins run is nice and smooth, The face side of the pump seems to have a slightly raised section in the middle as to keep the fins off that face, not sure about the other end. Anyway, by the condition of the impeller it looks like age got it- I had the new one but just had not got it done, boat was running fine, no sign of over heating, just bad judgment on my part. Supposedly, this boat only had 98 hours on it- if so, these pumps groove up pretty quickly.
For the chance of that O ring was out of it's place when I put it back together, which I did down in the motor, I'm going to put this back together and fire it up. Tiki mentioned he found a 1/16 spacer of sorts that you can install but seems like it would put more pressure on the impeller to seal it up? Did not get that one completely. So, since I'm getting so good at it, I will use some steel wool to clean things up and put it back together with a new impeller and see what happens.....man this tinkering can be painfull!
x
If you decide to replace it, consider the Hardin Marine pump. It has a replaceable wear plate.
http://rinkerboats.vanillaforums.com/discussion/comment/8788#Comment_8788
