Draining Drive Oil for Winter Storage
picturethispicturethis Member Posts: 103 ✭✭
this season I was losing a bit of out drive fluid (about a 1/4 quart in all ) from my 2000 bravo 3 ,  when I removed the props I saw that it was dirty wet around the bearing carrier seal (inside prop)    I drained out a little fluid from the bottom plug and it was still green.   To be safe should I drain the fluid for the winter and leave it dry?  Or leave it in there?
 the boat will be outside in the michigan cold so freezing will be an issue
Only time I saw the oil leak is when
I noticed 2 drops of oil coming from the end prop when the out drive is coming down from the all the way up position
I am a new boater with my first boat,  thats why some of my questions seem dumb
    1. Do not leave the outdrive without oil, a sure way to invite corrosion issues.
    2.  It is best to deal with that oil seal leak before it gets worse and/or lets water in. It only gets more expensive if you wait.  Call these guys, they are near Coldwater:  www.americandriveservice.com
  • picturethispicturethis Member Posts: 103 ✭✭
    My main concern is ...  if oil was leaking out is there water inside the case?
    I was going to have it the outdrive gone though in the spring,  is it better I do it now?
    Definitely better to have the service done now.  It is actually something that can be done over the winter without being put on the waiting list in the spring.
    Yes fix it now.  That is the norm.  You can winterize your boat, and pull the drive off, fix it on the side.
    edited November 2014
    Agreed, I have my outdrive service performed in the Winter.  Most shops are happy to knock a few bucks off for business when it's slow.
