MT, If your microwave is let say 1200 watts and voltage is 120 volts,it would draw 10 amps and probably more on start up up to 25% depending of the quality of the unit so a 15amps breaker would be fine, if you could look on the spec.plate of the unit it should tell you how many amps the unit would require. Paul
While on this subject I had to remove my windlass to work on it , Lewmar instructions said that the wire going to the windlass had to be 4awg, the wiring diagram from Rinker says 4awg. To my surprise the actual wire is 10awg on my boat and this is with a 70 amps breaker isolator. I guess I have to live with that since if I try to replace with the right size wire that would be a major job..... so Mt and RY I am not surprise of your finding..........." Paul
Wow! 10awg on a windlass is asking for trouble big time. Now I'm thinking I better look at some of my wiring. That windlass can suck up some amps (especially if one doesn't know what they are doing and use it to pull the boat).
Paul
X
On my boat the breaker size is 30 amps
Paul
X
Paul
X
X
X
X
Paul
