block heater?
You fellas ought to have seen me a few nights ago... Sick as a dog, dark as can be, and after watching the weatherman inform his audience that it would be dropping to 24* after a high of 40*, and not to break 40* the following day.... And I hadn't winterized my engine..  :o
Weather here is strange.  I've gone full consecutive winters where it never dropped below 30*, and then last season it dropped and remained below 20* for several days..  I was winterized then, though.. here's the thing: I'll use my boat during the winter when there will be a few days of 70* and Sun, with the fish biting.. so... I can't bring myself to do multiple pink loads and complete drains each time... Which brings me to block heaters...
The kind I speak of are 600w and fit into a freeze plug fitting... Slap her and tap her, and connect the cord to the plug, and the other end into a power source... This shouldn't give me a moments grief, right?  Am I missing something?  The oitdrive will be perpendicular to the ground, so it shouldn't be holding water.. between this and a lightbulb in the engine compartment for the hoses, I should be good, right?
  • rowboat212rowboat212 Posts: 74 ✭✭
    Please allow me to answer my own question:  DUh...
    Those aren't freeze plugs.... Those are casting covers.. a block heater won't work for me... Or y'all either, with sbc blocks... I obviously didn't think that through.
    I think I'll be buying a boatsafe marine grade heater... It's two bills, 1000w, and will keep the engine compartment toasty even during the hardest freezes, and thermostatically controlled not to run above freezing.
  • LaReaLaRea Posts: 8,069 mod
    With any heating device, question is: what will your insurance company say after your boat burns down?  With an approved marine bilge heater, you should be fine.  With a light bulb, the underwriters will be rubbing their hands in glee as they firmly deny your claim.
    But, of course, the heater is only as reliable as your electrical power.
    BTW: the block heater only works when the block is filled with antifreeze, otherwise it just burns out.
    Why would you drain the green stuff?
