trailer brakes
rasbury
Member Posts: 8,871 ✭✭✭✭✭
Howdy- did not see a section for trailing and figure most of the trailer issues would be with the bigger boats so here I am.....I had a mess of a trailer when I bought my boat and have been working with the brakes ever since the purchase. I thought I had one problem or the other that was causing my brakes not to work, now they seem to be working to well- II have 4 wheel disc surge brakes. I found a brake line that was leaking at a fitting and resolved that- I had my boat at my home and did that just before I moved it across town to the storage lot. I noticed when I was pulling it I seem to have a little more resistance pulling than normal and when I when to back the trailer in I was feeling a lock up of the brakes. I have replaced the back up lock out solenoid and pretty sure it is working ok. I did not have time to bleed the brakes- would my brakes engage and not release properly with air in the lines or do you think I just have calipers that are stuck? When I bought the boat I pulled all the cylinders apart, replaced one that was locked, new seals, pads and lubricated the slides with bake stuff....and the pins.....
Post edited by Babyboomer on
It's low tech old school but I've been trailering big boats for a while and I use a manual lockout pin in the hydraulic actuator for reverse. Your issue sure sounds like a reverse solinoid or a dragging caliper. Don't force it backwards. You can break a disc mount pretty easily.
Mike
Once reinstalled, you should be able to grab caliper housing and freely wiggle it..
I just did this last night on my truck... Three of four were bound up... They are absolutely great when they work, and ensure full seating of the pad on the rotor surface.. when they bind? There's a good chance you're dragging a brake. Not good at all.
I have a suggestion for you... Sell your 270 and buy TikiHut's 270. Then you know that the boat has been well taken care of. It seems like the PO of your 270 didn't so squat to the boat as far as maintenance goes.
That said... I have strong dislike for surge brakes... They'll fail you when you least need them to. They have manners you have to accommodate instead of just quietly doing their job. if you're towing a lot, I'd install electric over surge, and most preferred would be electric actuated hydraulic.
Home port: Hammond Ind.
I would offer that since you mention your not towing a lot, funds may be the question. Also, fresh or salt water? If I had the boat bucks I would ditch my surge brakes. If I had to choose between disc or drum and could not afford the total upgrade, disc brakes on all four wheels would be the first thing I would do, particularly if used in salt water. You can always add the electric down the road. Also since it is used I would pull the hubs and check all the seals and re pack the bearings before I pulled it anywhere.
Hope that helps, good luck!
Dave
Moon Township, PA - boating in the Ohio River
best to be safe, and there is no such thing as overbuilt braking systems when you need them... I once had to outrun a 12k# travel trailer coming out of a gap pass between NC and TN... Never again will I do that... It's a professional spectator sport, not a game of pick-up at the local gym I've since decided...
Thanks for the comments.
