bow thusters 342
Considering bow thusters.
What brand?
how much to install ?
    If you search on here there are a few good threads. I think you are looking at $5+
  • randy342randy342 Member Posts: 21
    Thanks for info.
    found moble place in florida to install (68 to 76)
    Will post name and how they work later. Install date  jan 9.
    If it is Florida bow thruster they do  really good work . They did ours and we are quite please with the result
    ,frenchship/ florida bow is installing on jan 8.
    Where did u put joy stick? What batteries did u use ie house,starbord or port?
    Did u hook up in main panel or direct to batteries?
    I had the joy stick installed right bellow the engines control. They used one of the engines battery on mine it was port one . Don't worry about the connections they take care of everything and it was professional installation. All connections for power on/off is on the joystick panel and it will cancell itself after a while if you forget to turn it off. And it is even programmable for some functions.Looks at the size of the wires they used on the batterie
    Here some pictures.
    That is one heck of a hole saw!!! I would hate to be using it when it bites really hard. It would twist your arm off.
    That is a good looking install! Very professional!
    French, great looking install!  Love seeing the pictures as it's installed!
    Thats called a core drill saw. They use those for concrete LOL
    I find it amazing that they would drill that by hand. I would think if its not perfectly straight it would affect the operation of it. Just sayin.....
    That is really neat looking.
    can,t wait to get mine installed.
    will post pictures.
    thanks for your input.
