Stereo speakers mounted on transom
golfdog
Member Posts: 151 ✭✭✭
Hello All, hope everyone is enjoying the holidays.
I have a 2003 342 FV with the built in fender holders. I was wondering if anyone has mounted speakers around the transom/swim platform area and if so, where. I think the sound system on my boat is fantastic but there are times when I'm trying to get the music loud for the people outside of my boat or in the water. When I get it loud enough for others to hear you can't hear yourself think when on the boat. Any suggestions?
Thanks, Jerry
Thanks, Jerry
I can never actually hear myself thinking, regardless how quiet it is...I may need to see a doc about that
That's my 7 cents...
I'm a big fan of loud music on the water, but the sound quality is usually much better when you have multiple boats all playing the same music at lower volumes. Low-wattage FM transmitters can be had for a couple hundred bucks, and they are pretty easy to use.
My boating buddy Dave has one that we use on every raft-up. If he didn't have one, here's the one I'd buy:
https://wholehousefmtransmitter.com/shop/whole-house-fm-transmitter-3/
But if you really want built-in rear-facing speakers, you have few options. For safety, stay away from the fuel filler hoses. Maybe you could do a 3-piece speaker system: a woofer flush-mounted in the transom locker door, coupled with cube satellite speakers mounted to the grab rail along the transom. (I've never seen a marine setup like that, but surely there's one somewhere.)
What's wrong with buying a good Bluetooth speaker? That will allow you to put it any where's.
Speaker L-Pad Attenuator 100W Mono 1" Shaft 8 Ohm
from parts express remove speaker and insure clearance behind the gunwale requires a 3/8" hole to be drilled at the location of your choice, I put them maybe 2" to the front of and even with the bottom of each speaker. the attenuator disk is probably 2 1/2" 0r maybe 3" in diameter. I can give you step by step instructions or you can give me step by step instruction on how to post pics
