Glue ideas
Stodge
Member Posts: 2,738 ✭✭✭✭
I'm thinking of putting an RBG LED light strip up under my swim platform. Trying to think of attachment options. I have heard, but never tried using 4200 as glue. Basically I'd be gluing the strip inside to the vertical edge of the platform (the rough fiberglass).
Thoughts? Experience? Wild speculation?
http://multimedia.3m.com/mws/media/323623O/adhesive-sealant-brochure.pdf
Mark
2019 MTX20 Extreme
4200 should work well. Remember, anything below water use 5200.
Above use 4200.
By the way 4200 is good for above or below water line used only 5200 for a permanent bond
here is the link for the silicon tube and the ends to seal everything at
superbrightleds.com
WFLS-GL1OZ 1 oz. Waterproof Sealant Tube Light Strip Glue
EC10 10mm Silicone End Cap 10mm End Cap - No Holes
EC10-4 10mm Silicone End Cap - 4 Holes 10mm End Cap - 4 Holes
ST10 10mm Silicone Tubing 10mm Silicone Tubing - 0.5m
Four Conductor RGB Power Wire, RGB-4Wire RGB-4Wire
By the way 4200 is good for above and below the water line 5200 should only be used for permanent bonding.
