06 270 New to me maintenance
As many of you know I bought my 06 270 this winter and I am creating a check list of maintenance to do before spring. Previous owner kept decent records of maintenance but I am the kind of guy that wants to be 100% sure things are kept up to date as best as possible. Survey did not have too much to say about service that needs to be done. Along with the usual winter check list, anyone have any advice for maintenance I should do or look out for? I know the drive oil has been changed and impeller has been replaced. Also drive was inspected and bellows were given the ok. Thanks for any advice.
Patrick
06 Rinker 270
06 Rinker 270
How many hours?
I would change fuel filters every year along with the regular oil changes, etc.
Do you have any automatic fireboy?
06 Rinker 270
06 Rinker 270
06 Rinker 270
I believe it does, need to verify.
06 Rinker 270
06 Rinker 270
Those drives liked like they were in the water a while. I would clean them up and paint them with an ablative paint for drives. Then I would wire brush the props and install new zinc. You could always have the props reconditioned too. I don't like the corrosion I see at the tilt pin in the last picture.
06 Rinker 270
06 Rinker 270
06 Rinker 270
06 Rinker 270
06 Rinker 270
I won't post the procedure here because the manual is copyrighted. Merc is planning to add it to the FAQ at mercurymarine.com. Until then, it can be found elsewhere with this Google search: "mercruiser paint refinishing gear housing Ditzler"
The process involves a 2-part epoxy primer and a 2-part urethane top coat. It's intended for spray application, but I'll probably use a brush. I am only doing small touch-ups, and I don't much care whether the result is pretty. I have an air compressor and paint sprayer, but hauling and cleaning all that gear would turn this job into a real pain in the aft-end.
Next challenge: finding the recommended paint products. The manual (circa 2001) recommends a Ditzler urethane paint that is no longer available. Here's the replacement: PPG OMNI MTK9300 replaces Ditzler DU9300.
I could not find an online retailer. From us.ppgrefinish.com, I found a local specialty auto supply store (Total Auto Parts, Springfield VA) that can order the paint. The products needed are:
(Ditzler-PPG part numbers)
DX-330 Wax and Grease Remover
DX-503 Alodine Treatment
DP-90LF Epoxy Chromate Primer
DP-402LF Catalyst (for DP-90LF primer)
OMNI MTK9300 black single-stage urethane paint (replaces DU9300)
DU5 Catalyst (for MTK9300 paint)
Buying minimum quantities, the kit will cost around $200. That's more expensive than aerosol cans of Primocon + Trilux. The question is, will it be more durable?
