Dual battery Rinker 232BR 2005
Hi I'm new to the forum,
Just bought a 2005 232BR.
I'm picking it up next saturday. Can anyone tell me if the 232 comes with dual batteries? If not whats the best way to install a second battery, and where is the best place?
thanks
    Welcome to the RBOC and good luck with your new ride. Lots of 232 owners here that can help you.....
  • luckydogluckydog Member Posts: 316 ✭✭✭
    Congratulations on your new boat and welcome aboard
  • PauldanPauldan Member Posts: 24 ✭✭
    This would be an option , easy to tell just view beside the engine on port side and see one or two batteries.  I have a 230 CC atlantic that I believe only came with one battery, however there are two now. battery switch is also a good way to tell. mine is only an on / off switch. I am probably going to have to change that out . does not even seem to turn any off at the moment.
    cheers!
    If you add a second battery, be sure to install a switch and an isolator. The isolator makes sure that both batteries are charged up. When I installed a second battery on my old 232, I had an isolator and a "make before break" battery switch. It made listening to tunes while on the hook more relaxing knowing that I had a second battery to start the boat if the other one went dead.
  • Skippy79Skippy79 Member Posts: 29
    would this be a good xway to set up a dual battery system?
    https://www.bluesea.com/resources/683
    Not sure how everything is connected at the moment, but will get a better view this weekend
    thanks guys
    This is more like what you want...
