Wet slip tips
Chrisvr6
Member Posts: 166 ✭✭
About to get a slip for the first time here in chicago. Can not wait. I'll be a nervous wreck I'm assuming? My boat bottom is in pristine condition but I'm willing to give that up.
* Floating piers are much, much easier to use than fixed piers.
* Covered slips are more expensive, but they protect the boat better (and make it easier to hang out at the dock in hot or rainy weather).
* If the marina has a lot of tide variations, and you need to tie dock lines to any fixed pilings, consider using TideMinders:
http://www.westmarine.com/buy/dr-shrink--tideminders-self-adjusting-chafe-protection--8420671
* You'll need to start replacing your anodes every spring.
Good luck!
We are fortunate to have good dock neighbors too. We have each other cell numbers and call if we see something amiss with a neighbor's boat. Gone aboard to turn stuff off or re-secure a canvas snap a time or two.
Good luck with your boat's new "home".
" My boat bottom is in pristine condition but I'm willing to give that up. "
I wouldn't slip my boat without bottom paint, although a few people in my
marina do. Those with no bottom paint will pull their boat every few weeks to clean the bottom.
BTW. there are no tides in the Great Lakes.
I almost forgot..... HAVE FUN
You'll never trailer again.
The convenience of being able to use the boat whenever you want is worth it's weight in gold. I know that if I trailered my boat, I would probably use it 3-4 times a season. Since it is in a wet slip, I put 75-100 hours on her a season.
You'll never trailer again!
Anyhow, I have had my undercoat for 3 seasons now, and we've barely had to touch it up, and only where we scraped it a little with the straps from the crane slings during haul out.
We applied 4 coats of barrier paint (Interlux) and then 2 coats of Micron CSC. Cost me a bit of money, but I can tell you first hand if done correctly it works (boat is always clean and stays permanently slipped during summer, and it lasts - no real maintenance to do after many years.
