Pump out adapter
Britinusa
Member Posts: 306 ✭✭
Do i need one of these adapters? if so what size? i measured my Perko deck plate threads at 1-3/4" but i only see these adapters in 1-1/4 and 1-1/2
The adapter you show actually is not the correct one for the application you show anyhow. It actually is for one that clamps onto that, and some places do have that with that adapter. There is one place I go that has that screw-on adapter and the clamp on hose. I always need to watch that it doesn't collapse my tank, but it does drawl out real well.
In your photo, it's the middle piece. You screw the fitting onto your boat, clamp the pump-out hose to the fitting, then crank up the pump. No fuss, no mess.
In rare cases, some self-serve pump-outs require that you bring your own fitting, so it's a good idea to keep one aboard if you travel often.
The one gotcha I'd watch for is a blocked vent line. A strong pump-out can collapse a tank if the vent is blocked.
