2005 Mercruiser 5.0 MPI Spring Start Up
Serenity
I am about to uncover my boat and have a question. I am in the northeast and the boat has been winterized. I am under the impression that before you start the engines for the first time in the spring-you change the fuel filters, distributor cap and rotor. You leave the plugs until after the initial start to burn off all the fogging oil. The oil was changed in the fall. Is this the procedure most do?
replacing them every season is not needed. Inspecting them every season is worth it. compare them against a chart for color and wear- you'll find an issue before it bites you.
Ignition wires are the same.. inspect them by folding them over themselves looking for cracks- make sure the loom keeps them away from each other to prevent inference and misfiring. look real close at your coil wire (center tower), as it sees a lot more action than the others. It'll show wear first.
the dizzy cap now- I'd replace it. the rotor spins like a top in a hurricane splaying spark to the points, and the points wear down along with the rotor's electrode- and it makes precision firing of the points sloppy... it can start finding better places to ground quick like, which aren't the particular points tower... which ain't good.. a decent cap is $10, takes all of ten minutes to install, and is worth every penny.
battery tender/charger- $free, if you have one, let it burst charge for the time to:
fuel filters- easy- cheap insurance- do it... five minutes. $10
oil and filter- easy- cheap insurance- do it... twenty minutes. $40
inspect the wires and plugs, re-gap, scrub, re-install... do it while the oil drains. $free
sea pump in the foot... an hour? got two? 1 1/2 hour? $40~$80?
three good hours tops... pull charger, slap the ears on, water up, turn the key..... smile while she comes up to temperature, so you can make sure the stat is originally closed, and that it opens when it's 'sposed to....
ain't nuthin' to it...
