Loose nuts on swim platform cleats
LaRea
Member, Moderator Posts: 8,022 mod
If you have pop-up cleats on your swim platform, take a minute to check them before you launch for the season. I noticed that mine were loose, and one of the nuts was close to falling off.
The root cause is that my swim platform does not have a flat surface on the underside of the swim platform. The cleat has two large bolts through the swim platform. On the underside, the fiberglass is slanted relative to the bolt, so each nut only makes contact on one corner.
The best thing to do would be to machine a 1-piece backing plate and bed it into the platform with 5200, but I won't have time this year. Maybe next year.
I was told to never use the pop up swim platform cleats to secure to the dock, as they are not rated for that and put an excessive stress on the swim platform mounting connections.
You may be seeing that since they are coming loose.
