Battery wiring
usafaviator
Member Posts: 41 ✭✭
Recently got an interstate deep cycle to add as a house battery and blue sea switch, now just need to mount switch and wire it up. I got 5' long 4 gauge cables made to reach the breaker panel where I will mount the deep blue switch. So heres my question, right now there are three positive connections on my battery, im guessing, the actual master positive for the boat/accessories, alternator, and bilge. I am curious can I connect the boat and alternator wires together, then run a single wire to the deep blue switch or do i need two seperate extensions to the "common" post on the switch? The blue sea switch is the 1-2-1+2-off switch (e9001). As long as the size of the wire can handle the amps this should work correct?
2007 230 ECC 350 Mag MPI Alpha 1
Post edited by usafaviator on
