Outdrive problem, need some help
BritinusaBritinusa Member Posts: 306 ✭✭
edited April 2015 in Engine Discussions
Changing out the impeller today, and the pump housing is trashed the inside if the housing where the shaft passes through is worn oval, there is some play in the shaft, how much play is normal?
Here is the water pump housing, the hole in the plastic part of the housing is not centered with the metal part, was this just badly made?
