Brass sea water pump repair kit
frenchship
Posts: 1,079 ✭✭✭
Hi,Did anybody had any experience with the kit sold on E-Bay to repair water pump grooves ?
Thanks
Paul
frenchship
Posts: 1,079 ✭✭✭
Hi,
Craig,Thanks for your feed back. In regards of grinding down the mounting tabs are you talking about this tab circle in black.
By the way I just find out that Mercruiser has an new cover for the impeller housing instead of being made of brass it is made of plastic that has a stainless steel insert that can be replace (86277A01) .I will still order the kit above but only the shim that goes in the bottom of the pump.
Thanks
Paul
11/07/14 is this the manufacture date on packaging date. According to Mercruiser it is
within spec. Also according to them if the bottom of the pump or cover housing has deep grooves on them it should be replaced, but no mentioned or any spec on how deep the grooves have to be. So better be safe than sorry I bought the new impeller cover housing that is made of plastic instead of brass and it has a s/s plate on it that can be replace.
I also got the s/s shim from the kit above for the bottom of the pump only.
A lot of the guys over on Offshoreonly and other forums say the circled tab is not needed and is ground off. As for modifying two of the bracket holes, I do not see how you can install the above SS wear plate kit without modifying it. I tried at first and quickly realized the 3rd bolt (closest to the pulley) that secures the pump will not line up properly unless you grind off approximately 0.0625" from the other two bracket bolt holes. I thought about drilling out that 3rd bolt hole on the bracket a bit to allow the bolt to line up, but then you are still left with the issue of the pulley being shimmed out too far. I would worry about belt alignment.
The new pump cover (86277A01) come with the SS plate,that can be replace,O ring, two blue plugs with the O rings.and it fit the original brass pump Sell for 75.00$ U.S. (140$ CDN :'( ). The two SS plates for the bottom of the pump are 20$ U.S.each, from the same guys that sell the kit above.
This is the link to the kit I purchased which has a plate for the bottom, a special impeller and washer for the top....if an impeller is 1/16 short in a "regular" housing, I don't see how it would work as it has to seal on both edges/top and bottom....
