Battery charger
BritinusaBritinusa Member Posts: 306 ✭✭
I did a quick search but didnt really find the answer.
My shore power cord goes to an outlet and the battery charger plugs into that, is that a normal set up? the reasoin i ask is the outlet is bad because my charger does not work when connected to that outlet but works when i connect it to a power cord.
I guess i need to replace the outlet, but if things are done different know i will change it?
  • MarkBMarkB Member Posts: 4,004 ✭✭✭✭✭
    My charger is permanently connected to go breaker board.
  • BritinusaBritinusa Member Posts: 306 ✭✭
    I just checked mine and had a Home Simpson "Doh" moment, there is a breaker for the Charger and it was tripped! thanks MarkB
    Glad it was a simple fix.
  • georgec14georgec14 Member Posts: 16
    my charger was hard wired in. I put a plug and outlet on it,so if I stay somewhere overnight and there is no proper shore power I can plug in extenstion cord. it has worked well for me. I can keep fridge ,lights tolet etc. hope this helps.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,895 mod
    George, you also could've just bought an adapter that goes from the 30amp connection to a regular 3 prong 120VAC end to connect to an extension cord.  You just can't turn everything on at once since you would probably be at 15amps.
