Fridge wiring
rasbury
Member Posts: 8,888 ✭✭✭✭✭
I recently was able to get my fridge working by replacing the controller....200 bucks, hope it lasts! At any rate, my question now is the wiring as the fridge does not seem to be on the circuit breaker panel- if the battery is on, the fridge is on. It also seems, although I need to confirm, if I turn the thermostat inside the fridge all the way down it does not turn it off but only the lowest setting...this is the std. fridge Rinker installed......what about that wiring, should it not be wired through the panel somehow? Also, I'm not 100% it's running on shore power. I have verified the power is hot to the fridge but when I had the fridge in my shop, when I tried to run it on my house current and disconnected the battery it would not run, just on the battery only. Not a big deal I suppose but when I'm on shore power it would be better to run it on that than taxing the battery....if I have the boat on shore power and turn off the battery, should the fridge then work or does a battery still have to be on for electricity to "travel" to the right spots??
Also as rinker312 states, you can turn down the thermostat until it clicks. Some dials have a '0' setting. This is off, so you don't need to keep shutting off the battery.
