What colour codes does my FV 250 ,2003, have?
I´m about to order gelcoat repair kits from Spectrumcolor but in my boats documentation there is no information on it’s colour codes. I have found out that 2003 Rinker used only one blue colour (Blue Ferro) but two white colours (Sand White and Bone). Rinker answered me that they cannot identify my boats colours from their original work order so I still don’t know what colour to order from Spectrum. I´m aware of the fact that I will not get a perfect match even with the right codes, due to the aging of the gelcoat, but I´d like to get as close as possible.
The general impression when you just look at the boat is that colour of hull is a little bit more towards the white than the cockpit is. Maybe the same colour originally but exposure to the elements, on the hull, might have caused the “bleach” or different colours from the beginning?
The two photo is to make some kind off comparison with a pure white sheet of paper, both on the hull and in the cockpit. The first is the hull and the second the cockpit.
Does anyone know how to tell the difference between the two white colours, Sand White and Bone, or help me identify my boats colours)?
Thanks
Johan
Best Answer
frenchship
Posts: 1,079 ✭✭✭
I would also buy both colour, and if possible some tinting colour for gelcoat. From what I see you would need some black and yellow. When you add any tinting colour use only the tip of needle since those are concentrated colour and before adding the hardener put a dap on of the mixed colour on to the gelcoat you want to match, then stand back a few meters and take a look . Look also at the flop side (looking side way at the colour if to light add the darkest colour that you use if to dark use the lightest colour. Be patient , when you are satisfied add the hardener to the mix.
Good luck
It's called Sand White, it's an off-white color. You will need to order the gel coat patch paste repair if your just doing cosmetic repairs.
