Galley door key?
Boat is a '06 FV250. Anybody know where to get a key for the door going down to the galley? If I can't get just a key, do you know where I can get a replacement lock/latch besides from Rinker, since I'm sure they buy them from a vendor? I bought the boat last summer, and the seller didn't have the keys for that door.
    Should be the same keys / lock used on Sea Rays
    edited May 2015
    Mobella Keys or Southco
    Patrick
    06 Rinker 270
    I assume you can open the door. Inspect the lock, there should be a code. Use the code and order a duplicate key (or two) from Mobella Keys or Southco, as per above advice.
    The code should be on the lock. I believe it is on the inside, when the lock is in the locked position. I ordered 2 extra keys last summer via code. I will have to dig up the website for you when I get home.
  • RuffLifeRuffLife Member Posts: 4 ✭
    That worked perfectly! I found the key code on the inside, and just ordered 2 keys. Thank You all for your quick responses. Its great having a site like this with people that are eager to help out a stranger. B)
