226BR Fuel Pump Whine
I am looking at a 2009 226BR with only 45 hours on the clock. I have noticed the fuel pump emits a high pitched whine after working for a while. I have had it pressure tested and the engineer stated it is running at 65psi rather than the 40 to 50psi which is normal. Is this a problem or a potential problem. Any advice would be gratefully accepted.
Best Answers
Dream_Inn Member, Moderator Posts: 7,877 mod
You can always ask that the pump get replaced before purchase. If I were purchasing the boat, I wouldn't let that hold it back but definitely ask either for the money off the price for a new pump purchase/install or have them get it done.Dream 'Inn III -- 2008 400 Express
raybo3
Administrator Posts: 5,592 admin
I would get a survey on the boat also. 45 hours seems really low. Good luck and keep us posted....2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com -
212rowboat
Member Posts: 2,593 ✭✭✭✭✭
The pump sounds like it's doing fine... The regulator, not so much. The pump is designed to provide more volume, as needed, to maintain the pressure... If the regulator isn't doing what it is supposed to do, the pump provides wide open volume, manifested as pressure... It'll run like crap, too, when it's getting that much pressure- the duty cycle of the injector (time it's open) is based off of a specific expected pressure that isn't monitored in these things that I know of, so, you gotta make sure that regulator is properly working.
This will be the third Rinker I have owned having had a 232CC and a 282CC previously. The 282 had a VP 5.7GXi in it and the 226 has a VP 5.0GXi. I have never heard the fuel pump on the 282 at all and my expectation is that they are virtually silent. Certainly, you should not be able to hear it over the noise of the engine!!
At this stage, I think I will throw the issue of the regulator into the mix and see where we end up.
Thanks again
Andy
Have sorted this out now. Spoke to VP in the UK who said the GXi engine from this year does have a noisy pump which is an issue they have sorted on the later models. Go figure!
Price of boat suits me.
Thanks again for all your help
