Outdrive having trouble going down
chrissyscall
Posts: 44 ✭✭
I have to push the button hard for the trim to go down? New button?? Or drive issue??
(1) Push button up WITHOUT it going through the click. This first step is to trim the drive while operating the boat. Once your boat is on plane, this feature allows you to gain a bit more speed by trimming the drive up a little, and it gives you slightly better fuel economy. You want to raise the drive up as much as possible, without porpoising (this is where the bow jumps up and down due to instability). The bow should be on the edge of jumping up and down, but still sit firm on the water. I basically raise the drive until I feel porpoising, then I lower it a little until the boat is stable. NOTE - when you are not on plane, you should have the drive all the way down. Having the drive down, helps you get onto plane faster.
(2) Push button up harder and go through click. This is only when you plan to trailer your boat. This should only be done with the engine off, as it can raise the propeller right out of the water. So when your at the ramp and move the boat onto the trailer or about to be lifted out of the water, you turn off your engine and raise the drive to prevent the skeg and prop from any potential damage.
