galley pump switch
so i filled my fresh water tank and flipped the galley pump switch to on but the light on the switch did not come on and the pump did not start.  I have looked at the breakers and they all look good but there are a view breakers with no wires connected to them.  Any suggestions on what might be the issue?
  • MarkBMarkB Member Posts: 4,006 ✭✭✭✭✭
    Which breakers did you check?  There's breakers under the steering wheel at the helm, and then there's breakers by the battery switch next to the transom.
  • fiestavee260fiestavee260 Member Posts: 10
    i checked the breakers under the steering wheel through the access panel in the washroom.
    check the wires at the pressure switch
    There are breakers at the battery switch as well. The galley pump might be on those breakers. The breakers under the steering wheel are normally only for the rocker switches at the helm. Your galley pump is not activated/powered from that location.
